2012 autocad block with the measuregeom command
Dominic
Hello, everyone. I have a big problem with autocad 2012. I installed the other one yesterday through a computer technician. tonight I was again put to see some program with some video guide to learn how to use it but as soon as I tried to click on the ruler it closed autocad and in the bottom right appeared a window that says. the video driver stopped working and was correctly restored.
is it a problem solved?
p.s. I want to specify that I have a notebook asus x53sv sx607v with 8 gb ram, intel core i7 second generation to 2,20 ghz and nvidia geforce gt540m with 2 gb dedicated. Can a computer so not hold autocad?
bhe.. .
three comments
1) What does the error message computer technician say?
2) did the assistance suggest you which drivers are up to date?
3) Have you read the pm that arrived to you?
and a consideration:
move everything in autocad area
continuing:
4) Have you installed the 2012 autocad service pack?
5) Do you do it with other commands or only with the measured command?
bhe.. .
three comments
1) I did not contact him. At least I won't be able until Saturday.
2) idem as above.
3) I read it.
continuing:
4) no and I have no idea how to do it.
5) for now I have found it only on this command.
only if you click on the command button or even if you type it?
with one line only if I click on the measure command does not close and does not give the error. with many lines if I click on the command instead gives the error.
even with many lines typing measuregeom in the command bar does not block.
