a super banal question. .discussed
  • Thread starter Thread starter davceccarelli
davceccarelli
to all I have just entered and presented in the presentation page, my name is davide ceccarelli, I am a first-level mechanical engineer and I am trying to put myself in play with solid edge,
I'm starting now, I've taken care of something else in my life but I think that even at 35 years you can always learn enough to want it.
My question forgive me but it's stupid, I'm following a course, I can move pretty well, but today when I try to do exercises I lock myself up on a "float".
work in an orderly environment, when I make an extrusion, I choose the plans posiziono, design,quoto then I mistake the constraints :or the feature goes ahead but with "problems" quacuno can give me a suggestion because you can not mistaken to quote a rectangle :o :o :o
Thank you so much!
You have to try to explain the problem a little better, maybe take a screenshot.
What do you mean "the feature goes on with problems"? is performed but you have the grey dart that signals an anomaly on the edgebar, or do not appear the yellow triangle with the exclamation point at the time of defining the extension of the protrusion and therefore cannot complete it?
especially thanks to the answer, well when I close the sketch does not give me problems but gives me the idea that it is not "completely bound" in the course that I did the feature became "black" here it seems to me to stay blue, even if I can go ahead and perform the other works, I do not have any triangle left, maybe it is just a bark my own or sometimes we can go on in the feature if we are not completely bound?
because you become black you have to activate the "color relationship" option in the "inspection" tab of the sketch lens.
with the deactivated option instead you can give any color to the sketch element (a little as it happens in draft"
