abaco floors divided by rooms
veru
Good morning to all,
is my first message and my first experience in a forum....I'm a little shady!
are at the first experiences with revit and I would like to know if it is possible to have a floor abacus in which the name of the room in which it is inserted is indicated for each floor.
Not really. I created several floor packages depending on the finish and substrate and designed them accordingly in the model. some premises have the same type, but there may be local, even neighbors, which have different types of flooring. After I created the premises. I have seen that when creating the abacus of the premises it is possible to insert the finishing of floors, walls, etc. of each room, but I do not understand why it is not possible that these fields should be compiled and cannot "read" the information already introduced somehow when creating the types of floors, walls, etc.
I hope I've explained... anyway thank you!
it is not possible to fill out the data of the local with those of the premises.
or enter the floor finishing in the room or add a parameter to the floor where you fill the name of the room where it is used.
