sigur ròs
I opened a dwg file created by my friend and since then every cad file creates me an acad.lps file, which the avira antivirus recognizes me as virus........how can I avoid all this..... thank you! ! ! ! !
It's a lightning virus. Is this the list?I open this old thread again because from a few days every time I open an autocad file, in the same directory, the file "acad.lsp".
I opened it with the notes, and it seems like a lisp to all effects. I don't know what the antivirus is.
before alarming those of the it, explain to me what this file is and why it is created?
translated. . .to solve this issue you have to delete all acad.lsp and acadapp.lsp in your machine. use the windows search engine for this. make sure that hidden and system files are activated in the search. after this your pc will be clean. i had this virus this week and searched a lot for that solution so i decided to share here. tell me if it solved your problem.
oh i forgot something. after this go to autocad support folder in c:\documents and settings\user\application data\autodesk\autocad20xx\rxx\enu\support open acad.mnl and delete the last 2 lines (acadapp princ).
to solve the problem you have to delete all the acad.lsp and acadapp.lsp files on your computer. use the "search" of windows ensuring that hidden and system files are activated in search. at the end the pc is clean. blah!
Oh, I forgot something. after that you have to go to the folder c:\documents and settings\user\application data\autodesk\autocad20x\rxx\enu\support, open the acad.mnl file and delete the last two rows (acadapp princ).
