add attribute to an existing dynamic block
danilo_t.
Hello everyone I am creating the dynamic lock of a door with the following visibility options:
standard
standard + but (panic handle)
standard rei
standard rei + ma (paid handle)
All right.
But now I have the need to insert an attribute in the definition of block obviously existing.
To this end I open the block editor and insert my attribute, except, I close the editor and the block appears without attribute. I change the visibility from standard door to standard port rei to see if it makes me insert the value to the attribute and nothing. so I try through the menu command insert>block. even this time nothing, or rather, appears to me the window of the attribute but I cannot insert values because by default inserts the standard port without therefore the attribute rei that is inactive obviously because invisible.
how can I create a field of insertion on the property bar that allows me to insert the value of my attribute or however can I add an attribute to an existing block?
thanks in advance,
Give it to me.
you can add it.
if you do not see it in the prroprietà panel is because, for that state of visibility, the atrib is not visible.
usually when adding an attrib to see it even in the already inserted blocks you have to use the _attsync command
did they try to sync the block? Battman command. Remember to select the block in the drop-down menu.
