Prog_Pie
I'm at the top of my arms and I'd like to have a tip on what to do:
I would like to analyze a tube flow (strange of afusolate shape and with different elbows) that I diseganto in catia...I would like to know to analyze it in fluent with three-dimensional object as I should proceed? ? ?
I create the pipe with part in cayenne and lust leaving a couple of mm or do I create it as a tubular surface? ? ?
then I pass in gambit for mesh (the cathean did not sway it right???????) here .. I introduce it with igs... and then gambit how does he interpret it??? surfaces or solid object??? ? I'm exc and I'm just disengaging the contour... and then the mesh do it only as surfaces?? Or not? ?
in gambit should I create some surface as a contour? ? ?
then in fluent... How do I know the name of the surfaces to impose boundary conditions? ?
thank you and excuse perhaps for banality
