aggiungere un nuovo "static structure" al "project tree" in ansys wb mech
domy89
Hello.
I'm a domenic student in engineering. I have to use ansys (version 7.12) for a research job and with no few difficulties I try to learn the program. Today I have the problem of having to add a new "static structure" to the "project tree" in ansys wb mechanical. Any of you have any idea how to do it? the result I want is how much you can see in the image contained in the link below:https://www.sharcnet.ca/software/ansys/17.0/en-us/help/wb_sim/ds_solution_combinations.html Thank you.
hi domenico, the thing is not complicated enough that you translate a new module "structural" on the old one and the game is done. as you will notice the module yourself you can insert it at different levels based on what you want to share between the two analyses. Once you do, you will see blue connections that will indicate the interconnected levels. If I had difficulty, ask me.
Hello, luca.
Thank you for responding. In fact I was wrong because instead of dragging I created the links back. instead as you suggest it works.
