alternative to exceed
  • Thread starter Thread starter libbero
libbero
Hello everyone,
I am an ing.mechanic at the first steps with fluent software.
in a discussion of this forum I read that xming is an alternative, for + free, to exceed to operate gambit.
would someone be so kind to explain where to download it and how to configure it?
Besides, okay x qlsiasi version of gambit and fluent?
and again, is it the only alternative to higher?
thanks to all those who want to help me,
seeusoon
Hello everyone,
seeusoon
I found him here:http://sourceforge.net/projects/xming/for sects it all seems to me quite similar to the good old past.
p.s.: Over! I didn't think it was used yet.
:smile:
...uguale a exceed?
quando ho installato exceed (exceed.powersuite.2008),
non ho dovuto fare nulla...l'ho installato e gambit lo richiamava
automaticamente...ma è troppo pesante e mi blocca un pò tutto.
ho installato xming, ho avviato gambit, ma non va...
mi dà come errore il seguente:
locating exceed installation ...
gambit failed in locating exceed installation on your system.
please try to start exceed manually before you run gambit.
starting c:\fluent.inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id3348 -new ...
gambit build sp2006032921.
warning : the current transport does not permit the attempted tcpip connection.
trans(socketinetgetaddr): tnamebysocket() failed
trans(socketinetconnect): trans(socketinetgetaddr) () failed
trans(open): transport open failed for tcp/notebook-libero:0
unable to open display
come faccio a configurarlo?
grazie
...uguale a exceed?
grazie
the problem seems in gambitche search exceed
I don't know gambit.
thanks cmq president. . . .
Someone else who can help me. . .
I would like to make a good impression with the teacher I work with,
Thanks again
demand, higher serves to emulate a x11 terminal on a windows machine, but normally the graphic bookcases in unix machines are different, higher also supports pex, for example.
I don't want gambit to need those specific libraries to work, xming uses opengl, you should check.
maybe on the gambit options you can set the emulator to use, have you seen if there is a corresponding setting?
or once I have known wordpad as "wordviewer" (I needed worpad but the program that had to launch it was stubborn to search for wordviewer) but it's not that it always works.
thanks really to everyone.. .
but the problem is that I am completely fasting these procedures,
and so I understood a lot of the advice you kindly posted to me. . .
for me it is already complicated to understand gambit, let alone the rest!
in fact as far as I understood gambit without the graphic libraries of higher
cannot work: but is it the only system for the pre-process phase for the fluent? Is there no other system? does not exist a version of gambit for windows?
I have installed xming...but a 2.1 mb program cannot contain the graphic libraries that need gambit: So I wonder, how does it work?
online nn I found a guide that explained me exhaustively
how to make gambit work in windows environment, and so I wanted from you
a council to succeed in the simplest way or cmq someone who directed me where to find these news.
I apologize for my ignorance.. .
But if I don't ask when I learn?
Thanks again
