Okay. I have to break a spear in favor of st.
If you try to work in this environment spoiled by the parametric discourse you can only find yourself wrong, you need to understand the philosophy of thest, that is, the quotas and constraints on the model do not exist but are defined at the time when you make the change. clearly this way of working has advantages and disadvantages....but also the parametric way, who never "triped" when he goes to make a change on the first feature of a piece that contains different?
on the st2 the interface has been slightly improved, but ahimè it is necessary to forget the old interface if... Among other things all other programs are going in that direction forced by microsoft.
