analisi con spectrum ansys
  • Thread starter Thread starter lo85
lo85
Hey, guys, I wanted to ask a question.
to carry out a seismic verification, you must create a combination with static forces + the seismic one (in my case obtained by spectral analysis)
it is possible to combine them both in one analysis,
Let me explain, if I do a spectral analysis, can I give other loads? For example, gravitational load, accidental weights on soles etc. so that the program gives me deformed stresses that take into account both the sisma and static loads?or must be done separately and then sum the results?
I sing it and I play it.
for those interested just save the results of the spectrum as a new load step of load (command write result), then you do a static analysis, and also this you save as load step.
at the end to have the sum just make a combination of load lcoper,add
Hi, I have your own problem.... I can't make a combination. Once the spectral analysis turns, do I have to save the load case? and then to combine it with the static analysis load case?? Thank you very much.
