naldo
Good morning, I would like to perform a 2d thermal analysis on a model created in solid edge. the problem is that if I amount a solid 3d I can't do the analysis I want. I also tried to create geometry with the designmodeler though when after creating the sketches I generate the surface, after I can not assign more materials to the different profiles because the created surface is unique.
I attach an image to give an idea of geometry.
