AMinati
I am trying to get the chart of the capacity of some containers to vary the filling quota. I realized the solid that defines the contents of the container in question. I created a curve (vertical line) from the lowest point to the highest point of the solid, on this curve I created a field point. I cut the solid with a horizontal plane passing through the field point, finally I created an analysis feature that calculates the parameter that represents the volume of the remained solid. at this point I have grouped the features between the field point and that of analysis.
When I try to create a user-defined analysis feature, the program recognizes the group and the volume parameter created by the analysis feature, but it doesn't seem to be able to calculate or find something and always gives me the following messages:
adu calculation failed for some values. results can be inaccurate.if I try to add the adu so created I get
missing data. impossible to create the feature.thanks in advance to any useful suggestion
aminati
p.s. using sensitivity analysis I have circumvented the problem, but with this solution every time I have to set the values manually of quotas.
aminati
