ansys does not recognize the solid
  • Thread starter Thread starter babbone
babbone
Hello I need help please,
I have an ansys wb 14 license to clarify, load a .iges file generated with inventor 11 but when I open the modeler some of the axieme losers turn out as surfaces to thickness 0.
I don't understand how it can happen, someone had such a problem and can tell me something about it?
thanks in advance
thanks in advance
if you have the possibility directly import the inventor part file or use a stl.
thanks in advance
hi babbone, did you try to open the iges file again in inventor and see if you exported everything well?
otherwise to 99% you lost some setting in importing the file into workbench. Anyway, I suggest you use .step unless you wash with cad siemens software. I use it only to import single-dimensional elements.
