ansys - structural static composite articles - urgent please
  • Thread starter Thread starter Cla
Cla
Good morning, I did a molding simulation with Moldovaex3d r17 and now I have to do structural calculation in ansys 2020 r1, I am following this guide Moldex3d-ansys But I can't do anything, I got stuck to the point he says:
"select static structural and go to tools and select input file...", what should I do???? ituo x favor are 2 days I lose time.
ansys is just over a month I started using
What's the problem? don't you have Moldovaex3d support?
r17 is a dated release, don't you have the new release?
have you mounted the fea interface module?
In the end I solved ... it is a kind of ansys bug, it is necessary to do if I remember well "clear generated data" in ansys and then the command "write input file" is available and you can go on as help.
