apdl how to run a for cycle to connect different knots.
  • Thread starter Thread starter NGC
NGC
I need to connect a knot to which I attach a force to a surface that has several knots through rigid connections. how can I implement a cycle for so that it automatically does it on ansys apdl?
My goal is to distribute a moment on an irregular surface consisting of sup154 elements.
to connect a node (master) to other nodes (slave) I would tell you to use the cerig command.
regarding the selection of slave nodes you can lean on a simple nsel.
the two commands you could insert them into a cycle for though without other indications it is difficult to try a solution in image.
