archicad 12 does not charge libraries previous versions
  • Thread starter Thread starter merlo82
merlo82
Hi, everybody, I have a problem that's driving me crazy and it's not working anymore. . .
I made a new computer assemble
64 bit processor
8gb ram
windows 7 installed.
had to speed up and solve so many problems, and instead I regret my very slow but reliable old laptop. . .
the problem is this:
on the old laptop I had installed and worked with archicad 12 (32bit)
and I could open various libraries and projects created previously with archicad 10 (32 bit) and archicad 9 (32 bit)... of course all crakkati. . .
now on the new computer I tried to install the 3 programs I had, so it looks like 32 bits
archicad 12 installed and you can work even if it takes more time to open than with the old laptop. . .
archicad 10 and 9 can't really install then I tried to load in 12 only the libraries of other versions. ..but opening the projects I had already made, and in which I had placed objects of the bookcases 9 and 10,
archicad 12 fails to visify absolutely nothing except external walls......
Since I will start new projects only with archicad12, how can I open the other projects I have to complete? ? ?
Please help me. . .
if the projects are saved in pln and not in pla it is normal that you do not load the libraries. you need to install the migration libraries on the graphisoft site.
However I would not go to write publicly to use softare pirate so light cuor... (illegal as well as I believe it is forbidden by the forum regulation)
Can you help me? I'm working on archicad 13 on a project and I've already made 3d.
I installed archicad12 at home.
how can I save the drawings of the vers.13 so as to open them with the 12?. and with the libraries how can I do?
try to save everything for version 12. if you used specific items of version 13, I don't know if you charge them however
