attributes with choice of value from a txt list
windsilk
hello to the whole forum.. Although it is not present.. on the forum compared to the past I gladly read you in the few free moments. .
I need your help.. , although using the function search throughout the forum, I hope to have posted in the right section.. I was undecided between this and that vba...
I need your help. I would have to exprapolate from a series of dwg that has passed me a colleague: mad: of the data to pass in excel.. dwg is composed of a series of multi-faceted polylines gradually with a sequence of mtext numbers and letters depending on the type of building... I said some data. building area polylinea, number of floors building, layer on which it was designed..which indites the type of soil... clayey.. rocky. This information is already present in the form of individual text lines.. inside every polyline. .
classic autocad data extraction.. while looking and trying every little.. option does not allow me.. associate the correct texts with the right polylinea.. with its area and layers.... area and layer are perfect, if they examine the properties of the polylinea and selection area and layer...while the texts inserted in every polylinea of the design... sembrerebb are inserted in random order. . may my inability
Except that the colleague didn't use the attributes. :frown::frown:
I tried to search online also on foreign forums.. some lisp or vba application.. automatically convert a simple mtext text string into attribute adding tags and prompts or randoms or requiring user names.. but above all attributing as "value" value the text contained in the same string of the text that I have selected that I am trying to convert...but I have desisted. . .
I've created a block. with the 4 attributes.. that I need.. with "increment 123" program downloaded from the autodesk site I managed to overcome the problem.. of the numbering of digits or progressive letters but.. using a block with attributes.like lock to insert in closed polylinear gones... already created. I wanted to ask you:
1) there is a possibility.. once you enter the block with attribute within the polyline--or with the autocad insert or in increment 123... the possibility that you automatically read the value of the polylinea area that contains it..? today during the insert block + attributes.. I am forced and edit the area field and select the new polyliea again. . .
2) I can choose once the block is inserted.. the moment you open the attribute interface. . select the respective prompt.. type number of building floors... select the number or numerical value or not from a list linked to that specific tag... instead of repeating it every time... as well as for other acts... I can't use the copy and paste.. . attributes,
3) to display as other... given the name of the plan.. it is correct to define an attribute.. with syster variable is set dlayer..even here you could choose a value by choosing it from the list of plans... present in the drawing.. or from a previously created txt list that contains a number of layer names or other text strings.. I can select.. not with the copy and paste.. .
thanks for the attention... and any help. .
ps. I think who you use... road map.. these operations are routine
Well... everything is possible, but making an ad hoc lisp is not exactly a two-minute thing.
if you attach a dwg that contains the block with attributes you created and some complete polylinea of the texts inside maybe someone comes some ideas.
