autocade architecture equivale to say revit architecture?
danilo_t.
excuse the question perhaps a little stupid but the doubt came out when looking on the site hoepli a valid book to be able to learn well "autocad architecture" I jumped out books that contained in the title "revit architecture". I take the opportunity to recommend a good book, it is fine even if expensive the important thing is that it is clear and above all complete.
Danilo
no danilo, they are 2 different products, and if I can recommend you let go of aca and throw yourself directly on revit
Thank you for your answer. but I draw on revit can open my file in autocad to view the plant? or for example from the plant designed on autocad can I get to 3d on revit?
last question: can you make perspective views (of the section for example) as well as prospectuses and sections? and sometimes there are commands that allow you to do the times a star (for example) with ease?
