automatically collect all edges
Alx84
Good evening,
I would have the need to collect all the edges in many laser cutting profiles, each of which resides in a different dwg file.
in total the profiles are more than 300.
is it possible to automatically execute this process?
the profiles are composed of arches and lines, no polylinee nor spline.
I attach you a program that performs only the connection inside the design by manipulating lines and arches and therefore, in a semi-automatic way (because you still need to open the 300 files), speeds the operation.
1 -open the file and edit the radius value of connection in the row: "(setvar "filletrad" 0.5)"
2- upload the file ral.lsp with appload putting it in the 'starting group' area so that it always loaded
3- open drawings and type ral 4- visually check the result if there are arcs present in the profile.
attention: the ral command uses the autocad command "agreement" with the option "p" (poliline), very often in the presence of arches the final result could be different from the desired one! !
Hi, Dieva.
Fortunately I found a solution that allows me natively, through the software with which I modeled the plates to make the fittings, without having to then make further steps.
However, thanks to the instructions you gave me, I will keep them in mind if more complex situations happen to me.
