calcolo volume
  • Thread starter Thread starter eugeniobene
eugeniobene
with solidworks can you calculate the volume of a component we modeled in 3d?
Thank you very much in advance :d
with measure I never did, usually I use mass properties (menu "struments" or bar "evaluate").
You're right, I said a terrible cow, I meant mass property, I apologize to eugeniobene for hurting him.
as many things just write in the help of slidworks or in google "calculate volume"....it is also done first
and if you want to put the weight in kg?
in the summary information gives it in format 102000 instead of 102kg.
How come?
and read the guide and sew in the fution?
if you have the model set in nanochili the weight is returned to you in nanochili.
or, I quote from the "options" guide. opens mass/section property options, to view results using different units of measurement. "
How come?
question already made and already answer....property of model 3d...measure unit....from grams to kg
