s_c_90
Hello everyone, I am new to the forum so I apologize in advance if I commit some label error.
I have been working on the fem model of a single lap audition in composite bullonate; one of the two plates is stuck at the end, while the end of the other plate is loaded with a traction force.
the purpose of the study is to validate whether it is possible or not to compare the behavior of the plates that compose the test to that of a circular plate with external radius framed and with a rigid lock at the center that simulates the behavior of the bolt and on which the loads are concentrated. therefore I need to extrapolate the loads agents on the plates from the fem model of the test.
I have done several tests considering the fsum or nforce command and selecting the nodes and elements within one of the two plates or considering a half of the bolt; Unfortunately, the results are not satisfactory.
the question that I ask you is therefore whether according to you is correct the procedure followed to calculate the loads agents or if it is totally free of principle.
Thank you all in advance
