calculation of the torsion angle in a frame
  • Thread starter Thread starter Lin14
Lin14
hello to all, they are struggling with the simulation of a frame consisting of 4 beams, two transversal and two longitudinal, which form a rectangle. I have to check the torsion of longitudinal beams. to evaluate the angle of torsion I suppose to be able to use between the outputs the flexible rotation in the final section. the problem is that I can't decipher which angle is what calculates ansys, that is if it is a twist angle or if it calculates the rotation of the whole beam, because I have results different from those I expected, and in addition I have different results if I imposed a remote point in the same point or if I consider the geometry. on the ansys guide is not explained much regarding the flexible rotation. Can you tell me how this command works?
1639322903795.webpI made the frame in spaceclaim, with its sections. in mechanical I have inserted load and constraints (the beams are blocked with bonded contact). I need to calculate the twist of the longitudinal beams (l), that is the angle of which the sections rotate around the x axis. I thought I could use rotation flexible probe, indicating in geometry the entire longitudinal beam, but I think that is the rotation of the entire beam that tends to go down, so the angle that the axis of the beam forms with the x axis. How can I do, instead, to have as a result the angle of torsion?
beyond the software.. define a local reference system in axis with the two beams and evaluate the rotation of beam knots compared to these new reference systems
