cannot open this file no translator is available ...
  • Thread starter Thread starter nicodm
nicodm
Good evening to all,
I have a big problem with a set.
In practice, the program was arrested, and now I can't open a set.
This message appears:
cannot open this file no translator is available for this file type
I don't know what to do!! !
if it can be useful, in the folder where it was saved the file no longer appears the .asm extension but only .cfg!
Niche
the file is corrupt, you can no longer do anything except: 1) remake it, 2) send it to siemens (if you have maintenance) and make it repair (if repairable) in 2-3 days of work.
I remind users that posts must summarize the theme of the post.
titles of the "emergency problem" type are too generic.
I changed the title with a more relevant one
Niche
try to look into the temporary backup directory, and then look in the work directory if you find any .tmp file extension. if you find qusto files, change the extension in .asm and see if you solve something.
Last chance, find the asm file you were working on, maybe you saved it somewhere else.
This joke does it to me from time to time.
is as hunter says, the file has not disappeared from the directory but no longer finds it with the same name, but name_strano.tmp
I usually copy the name from the .cfg that remained and gave it back, clearly with .asm extension.
I always worked.
