gcb
Good evening, I hope you can help me because since I use sw (just now, and by self-taught) I have the constant feeling of having wrong approach.
I deal with civil carpentry (houses, railings, etc.), so basically profiles and plates. the goal is to have:
- a series of normal cutting and drilling for individual bodies that make up the part (say format a3)
- an assembly design for the workshop where the distances are indicated between the various bodies that make up the structure, the welding, etc.
- a mounting design to be shipped to the yard where the welded pieces will be placed and fixed, perhaps with other elements defined on other parts.
I create the model with the structural bodies for the profiles and make custom-made extrusions for the plates, concentrating the model as much as possible in a single multibody part. I then go to compile a series of custom properties in the cutting distinction that include the brand of the piece (e.g. "pa" for a plate that would then be marked with the punching machine), the thickness of the plate when I make an extrusion, the material, etc.
All right (other than some neophyte blasphemy) until model, then I have to put in the table and start trouble:
on the normal cut (remember, a sheet = an element) I should report a note the name I gave to the element and total quantity. These values are already part of the cutting distinction on the multibody. the optimal would be that the cartiglio "deducesse" from the view of the individual body that contains the design these elements, but there is no way to connect a note to the value of the property. there is no way even creating the note directly on the view: Unless you use the association line - and I do not intend to do so, I want a pretty big writing that says to the worker "this is the piece a, cut 50" to place where I want - the caselline of "connect to the ddt properties" remains duly unselected. the solution would be to insert on each sheet a ddt and hide all the lines that I do not care about, but you put a life, and I would like to know if there is a more automatic way. or if there is a way to "direct" the cartilage that takes what is found in the sheet and pulls out the properties, without saving every single part of the multibody as a single element (also because the quantities in that way go to a ball).
thanks for the help
thanks for the help
