change language in ptc creo 2.0 (student edition)
  • Thread starter Thread starter TAURUS77
TAURUS77
Hello, guys! !
before someone sticks to me...I looked in the forum but I found nothing on how to change the language in creo 2.0 student edition from English in Italian.
Could anyone please help me? ? ?
:smile::smile::smile:
the options to add to the config.pro are:
dialog_translate yes
help_translate yes
menu_translate yes
msg_translate yes
in this way you should translate everything with the language of the so, which is the Sicilian supposed :tongue: :biggrin:
Bye-bye.
help_translate yes
menu_translate yes
msg_translate yes
Bye-bye.
Hello my friend!!!
but you want to put that instead of folder read "cartedda" and that instead of the logo of windows appears a beautiful cassata and in the background cannoli at will and dulcis in fundo when I start the pc sings me "ciuri ciuri" and "vitti na crozza" .
I forgot the mouse pointer is a mini Sicilian cart all colored.:cool:
Bye-bye.
I used the free version of creo parametric 3.0 for 30 days setting the config.pro as already done other times. And all right here. Now I have expired the license and downloaded the student edition version valid for a year.
I tried to set the path from: for my template but there was nothing to do continues to "read" the anxious settings, inches, pound etc. I tried to go to file configuration editor options to force the settings of my config. But I'm losing my time. you have some suggestions to give me
You would do me a huge favor "I would have to work" in theory
...I tried to set the path to: for my template but there was nothing to do.. .
What do you mean here by template? Do you want to use a start part that you created with the commercial on a student?!? if it is so know that it is not possible... You should remake your start part on the student and start there to maintain compatibility.
the path you impose da: in creo link properties must point to your file config.pro
