change thickness to a sheet with inventor
  • Thread starter Thread starter Francesco Coruzzi
Francesco Coruzzi
good morning, I have a problem of this type: I have a folded sheet shelf thickness 0.9 mm., for another application I would like to use the same form of sheet but thickness 1.5. Is there a way to change the thickness while keeping all the work done? I don't want to redesign the shelf.
I add that I am trying with the command explains, increase the thickness, but can no longer fold the part with the fold command.
thanks in advance for the indications
hi, make a copy of the file, go to the properties of the sheet and change the thickness. each processing will be adapted to the new thickness (if it does not conflict with some parameters) and also the flat model will be in place.
Thanks for the advice. I add a detail I leave on one side that is not a sheet but a solid.
I turn it into sheet metal and from there I try to change thickness, I can explain it to change thickness but I can't do the fold command
Then change thickness, return in part and change all the inner rays of the folds you made by putting them equal to the thickness and all the external rays = inner radius + thickness. Then try to explain it.
