colors ral
  • Thread starter Thread starter Guariz
Guariz
I would like to know if on inventor 2010 are already set the colors ral without doverseli create all on the style editor. Thank you.
help!
I am trying to import ral styles: I copy ral.styxml downloaded from the sites above in date design, the amount with style editor, tells me that it converts it into the new format and... now? Where are they? I can't find them! with styles I always messed up.. .
Bye!
help!
Bye!
take a look at the links on this discussion, however, do not worry:
if you find where they are finished, say it to me too!:36_1_28:
You're not the one who messs up, it's the management of the aspects that messed up everything.
hi, I took the ral colors from the site inventor wizard.....quelli with extension "adsklib", there are 3 files.
after that I followed the instructions contained in this site:
http://forums.augi.com/showthread.php?79387-inventor-ral-colorsAfter following the instructions I opened any component and clicked on the button to view the "browser waits"....from there (button to the bottom left) I imported the files I had put before in date design.
Okay, now I've made it... I downloaded from the same site the single file at the end, which is different format and therefore obviously nothing worked.
Thank you all!
p.s.
tarkus, good luck to you with the heral now, since I understand that we were put the same way :biggrin: ...
Okay, I got it now. .
p.s.
no, at the time I solved it for ral colors, it's for another .styxm always ral but different from the previous one, which I uploaded to see the difference, but that I never understood where it ended.
I gave up and displeased the rals I...
with .styxm I didn't even manage: using the three files indicated by manumasss71 (which in fact are .adsklib) everything went to place, I downloaded them always where it indicated.
Bye!
ho inventor 2014, ho scaricato http://www.inventorwizard.be/textures/index.html .adsklib files for ral colors for inventor 2013 onwards.
I opened my template for the parts, then the "browser waits", then on the bottom left "open existing library", loads all the libraries and I find them in the drop-down menu to change appearance.
But if I go to create a new part I can't find them, and even if I reopen the template file, the ral libraries are gone.
What's wrong? how to import them so you always find them in the browser you wait?Screenshot 2014-07-08 15.40.29.webp
