narra12
in wb I should combine results obtained with a static analysis to those obtained with a spectral analysis. I have seen that this discussion already dealt with the same subject https://www.cad3d.it/forum1/conversations/combinazione-analisi.99207/ .
I would like to understand whether there is a simpler method or whether that dealt with in the discussion is the only way
in case it was the only way I would like to figure out how to save the results as a new load step of load, you have to use the write result command that I do not find.
