command flatten su autocad 2015 per mac
  • Thread starter Thread starter elisabettabot
elisabettabot
Hello everyone.. I have a problem with autocad, in a plant I have the lines that on the z floor are all at a different height, and I would like to bring them all on plan 0.. I read that there is a command that is called flatten but on my autocad this command seems not to exist.. I also read that you should install these famous express tools but I have no idea how to do it.. Can anyone help me? I have a mac and use autocad 2015. Thank you.
I had already read but I understood very little..type seems that he or she solves like this:
assign to a button this macro:
^c^c_ucs;_select \_move _p;0,0,1e99;_move _p;0,0,-1e99;
I have no idea what it means
@elisabettabot
do something simple: downloaded zeta.lsp
upload it (it should be enough a drag and drop. basically throw zeta.lsp into the autocad drawing window) at the limit I think it is the command load that is located inside tool (memory sink).
once done this write: zeta
and press forward.
will ask you to select what you want to move and at what altitude you want to bring the lines. It usually takes 0.
Unfortunately these commands (flatten and zeta) do not always have full success. it could be necessary to explode some entities to complete all the passage. the only real solution is to try and try again until everything is in place.
it may also be necessary to have to cancel some quota if the reference is to points that belong to a different plan.
p.s.
wanting you can download zeta.lsp from here:http://www.emicad.it/emicad/simbolicad/lisp/because I did not find it on the other site indicated
