command list
  • Thread starter Thread starter BRM
BRM
I would like to know if there is a list of the various references for the options of solid edge st2. example in the draftlist file are the settings for the titlepos and originx tables etc. I would like to know how they call all other options such as the docking point to be inserted in the draftlist to automate the table positioning in the drawing.
You mean the list? Are you using an English version? However on the help if you are looking for "list parts" you find what you need... see attachments. Hi.
thank you, this is the help. I would like to know what I have to insert in the drftlist file as point entry hooking page, the Solid Edge command.
you have to put which angle of the table to use as a positioning reference on the drawing. I usually use the one on the lower right and on the coordinates I put the values to place them above the cart. Unfortunately solid edge takes 0.0 coordinates to the bottom left of the template and when you change the background of the cartiglio you widen to the right for which you move the cartiglio and the table never remains connected. I made a request to the starting point exchange siemens since in the drawing boards the cartilage is always on the bottom right or at least to be able to choose which point 0.0 set on the carts.
maybe I didn't explain, if you open the draftlist file in the \solid edge st2\template\reports folder, you will find a set for the table
beginning
configname =xxx
textstyle=xxxtesto
fontname=arial narrow
fontstyle=1
fontsize=0.0028000
invert =1
titlepos = 1
originx=0.2138024
originy=0.0626071
spacing=0.0015900
maxheight=0.4000000
here I find the coordinates to insert the table but I would also like to insert the string for the page connection point and that to activate the original predefined for positioning.
How can I do that?
the draftlist.txt file autocompone when you create a table itself.
the coupling points are written with the handlepoint entry.
the item to insert is handlepoint=number, where by number you have to put
1, 2, 3.
If you use the item "top left" on the draft list nothing appears, if you use the other one the handlepoint=1 for "top right" =2 for "bottom left" and =3 for "bottom right".
for the default origin you must write usepredefinedorigin=1
this row must be inserted between invert and titlepos and between titlepos and originx as the example below
configname = try
textstyle=normal
fontname=solid edge iso
fontcolor=16750882
invert =1
handlepoint=3titlepos=1 pre-defined door = 1
originx=1.1840000
originy=0.0650000
spacing=0.0015900
Thanks is exactly what I was looking for.
where can I find the list of these commands with explanations?
try to see on the help but I doubt that there is a part that explains how and where to edit the solidedge txt files. I learned these things to the course I did years ago and to give you the explanation I did nothing but edit a table a couple of times and see on the draftlist file what went to change and consequently I answered you.
Good day to all
I hook up to this discussion because I wanted to know how I could customize the list table parts once and for all, and not every time I make the table; I don't know if I have to create a custom list within the draftlist or act otherwise!
Thank you for your patience...
the draftlist.txt is a starting point, but in the end it is better (especially if you work with multiple pcs) 'centralize' the file on a server: so all have the same settings (there can be the risk that everyone edits without knowing what they do) ;
but above all between a solid edge installation and another you do not lose your settings (it is cmq recommended backup).
from the main menu, options of solid edge / file location you can change paths.
Good day to all
as already said the draftlist.txt file autocompone when in the draft environment you create a list of parts and save it, so you don't need you to edit the txt file but you create the various configurations of tables from the draft and then copy the draftlist.txt file in a shared server folder and from solid edge options to the entry position file/rapports published the new path so all pcs will use the same configuration, exactly as
Okay, thanks for the clarification, I thought customizations had to be done in the "iso draft" environment under the template, instead from what you say is enough to create a table configuration in the generic draft and then save it. greetings
Excuse me, but to save her what you mean?
What is the procedure?
When you create a list table, you can call it as you want and save it, so you always stay on the draftlist.
a fabio71 indicated to copy the file that is usually found in c/programs/solidedgexxx/program/reports in a shared folder (usually on the server) and solid edge settings to edit this file from the server on each connected pc so that everyone uses the same configuration
will there be a way to know the inner name of all solid edge commands?
it is easier to expose your request "I would like to do so... can you?", so experienced users know where to go to parade.
for "internal names" usually means programming in solid edge with development tools and programming language vb .net c++ c#,...
for programming are not able. but to know how all the various options are called as you do? example titlepos for tables.
It's something you don't find written about the help. I was taught at the solid edge course, but only the necessary ones, like editing the propseed.txt file, or theholes.txt and more recently the custom.xml file regarding the stairs. for what you have to do edit this draftlist file you don't need, because as already said this autocompone from the screen in the draft environment.
If you are looking for part list/create a distinct find what the various voices need...see image.
