command stampa slow
  • Thread starter Thread starter silve19
silve19
Hello everyone, I have a problem with the press command on lt 2009:
after clicking it pass at least 15" before displaying the print window.
Is there any variable that controls this command? ?
for the last time (and I think it will not be the last).
1. read the forum rules
2. we present
3. is written in the correct section (not in mechanical design, what is it? )
Do you do this on all the drawings?
I reinstalled autocad, but nothing happened.
for the service pack I ask we have it and I try
I installed the service pack 3 but nothing changed! !
always slow print.............
Where can I see if the service pack went well? ?
I don't know lt but, generally, if in the menu click on "?" you should give you " product information ", including installed sp.
Also from me the print is very slow but the fault is, I think, that the printer is on the net and connected to a pc with win98 while the rest has xp. (all used applications print slowly, not only autocad )
I found a suggestion that worked with me.
do not need to reinstall autocad:smile:
1) try to delete all old printers installed in windows that you do not use + (to me it is immediately improved)
2) you need to change the registry hkey_current_user\software\microsoft\windows\
currentversion\policies\explorer
insert a nuov word value (reg_dword) you call it linkresolveignorelinkinfo and set with value 1
(to me goes like a lippa:biggrin:)
the suggestion I found in English on the site of autodeskhttp://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=2883747&linkid=9240617
You say it can work for me too?
I just bought an epson stylus office b1100 because it makes me
the a3+ and comes up to 33x110 cm in user and installed it on my pc
64-bit win7 64-bit and ram + of what you need, drivers, even on the internet on the epson site are dated 2009, and go like a snail with any file type.
I asked for epson assistance and sent me a cleaning procedure
of files and restart of the computer, saved the email page (3 pages pdf only text)
to print them before cleaning time used + 15 minutes
Meanwhile in the office my colleague puts between things to throw a laptop
of the acer an aspire 1300 (amd atlon) quite dated with 300 and mega root of ram and xp for which a splinter:biggrin:
install the printer drivers and send the 3 epson support pages to the press.
I do everything that says epson assistance, reboot and nothing changes,
always slow
I rewrite to epson assistance saying that nothing has changed and the answer is a thank you email for contacting epson assistance.
as I am an educated person I do not answer them by sending them to c..
However now I try to see what happens with the procedure described above
if by chance someone has the same printer and the same problems
Let's hear:
greetings
