connect polyline to a block attributes without data field
luiov84
Hello, everyone. I've done a lot of research and found no answer.
substantially would need to connect a polyline to an attribute block. without passing through the data field.
I have many polylines to associate with the block. Of course, connecting the polylinea to the block attributes I need to have the polylinea area.
Thanks for the answer.
I attach a cad file with the attribute block I use.
View attachment Esempio.dwg
while I connect polylinea through data field, I manually insert the value of square meters
depends on the complexity of polylinea.
if it is a rectangle (I imagine a room) just copy the polylinea and its data field in a new location, change one of 2 and see how it updates only any modified :-)
