continuity control sketch in nx
acarlett
Hello everyone,
working in nx I have a problem in performing the revolution of a profile 2d.
sometimes the sketch is not completely closed in some points and for this nx does not run the revolution. is there a procedure in nx to verify that a profile is closed (as happens by cat)? is it possible to reason for layers? or check that the profile on a layer is closed?
Thank you for your help.
is there a procedure in nx to verify that a profile is closed (as happens by cat)? No. . to do so you need to write a check-mate procedure.
or use some workarounds how to build on a flat surface and see where the asterisks put you. . .
is it possible to reason for layers? or check that the profile on a layer is closed? No.. ug works little by layer... It doesn't make much sense.
Hello everyone,
hi, I use a workaround to see if a profile is closed or not: I use the bounded plane command and select the sketch rather than another profile. the command fails if the profile is not closed and shows you where.
is there a procedure in nx to verify that a profile is closed (as happens by cat)? No. . to do so you need to write a check-mate procedure.or use some workarounds how to build on a flat surface and see where the asterisks put you. . . is it possible to reason for layers? or check that the profile on a layer is closed? No.. ug works little by layer... It doesn't make much sense.
I'm sorry, I didn't read your post completely and I did a double... Sorry.
is there a possibility to obtain a list of coordinates of the points where the asterisks are inserted in nx open? or a list of objects on which the asterisks are placed, always in nx open'
