controls ansys thesis reticular travailing
  • Thread starter Thread starter meccalbi92
meccalbi92
Hello everyone, I am a three-year-old ing.meccanica student, I miss the last exam and I started the thesis.
the thesis argument is the structural analysis of a reticular beam, where the objective function is to minimize the weight of the structure.the shape of the structure is circular of diameter 20 m and high 100m.
the professor told me to start from a simpler structure ie cylinder more cone and then optimize it.After creating all the knots and elements in batch mode,I came to the point to insert the first load condition, ie the weight of the structure and then analyze it with 10 times the own weight.at this point I stuck and I wanted to ask you for the calculation of the weight I always have to do it in the prep7 or post1 phase? Why is the etable command in the post1 to create the volume database in the prep7 a similar way to do so? You can give me some advice
Thank you all.
What kind of elements did you use?
I am using beam4-type elements...the structure should have the shape of a dome we say, but I did not understand if this form can be achieved by optimizing or I have to set it from the beginning...it is the first time I use ansys then apologize if I say stupid unfortunately the prof is not very available
depends on what you mean by optimization.
I mean structural optimization to find the most satisfactory configuration.... in the optimization process I should insert both my sizing and layout variables and the objective function that for me is the weight.
a little something you should find on the forum otherwise you can try to see in forums dedicated to ansys in English.
I suggest you do the tutorials first.
I thank you for doing so... one last thing I use to plot the forces that I apply to knots because I don't know how to do it, to plot knots and elements I use nplot and eplot but the forces did not find the command
you can plot them only when you are in post1 i.e. at a solution acquired.
should be like nforce I don't remember exactly.
But if you do anything like a leash first.
plot--results--nodal solution----
hi volaff I wanted to ask you something,I managed to solve some doubts,now that they are in the optimization stage by chance you know which command I have to use to optimize the geometry of my structure? regarding the thickness of the beam elements I used the opvar command do I have to use the same?
I can't help you.
hello meccalbi92 since I am having your same problem about the optimization of dome layout I wanted to know with which command you solved the problem. Thank you in advance.
