Hello, I kindly ask if you can convert a .rfa file to an interchange format with other 3d software for example in .sat or .step format.
thanks for availability
Thanks for the answer, I probably misunderstood, but I do not have revit for this reason I asked if someone could import it into revit and then export it to another format.
I managed to import it into inventor, but then from inventor it does not make me export neither in sat, nor in step; probably because it is a "solid" without thickness, however it could be enough because I just have to make canonical views.
