correctly export annotations and blocks
  • Thread starter Thread starter 3DBix
3DBix
1- annotation
is there a way to "say" to revit that if a text is centered in a revit annotation when exporting to dwg should also be centered the multiline text that generates?
You do not ask for a particular justification like those that has autocad (as long as you revit from that point of view seems "paint")... but are 2 sw of the same mother house, a small upgrade also on the management of texts in revit or at least an alignment between 2 after 22 years from the acquisition would be a discreet step forward from the point of view of the output.
2 - blocks
mod. sarcasm = on
I would like to ask too much
mod. sarcasm = off
is there a way to set revit so that you carry in dwg a file that inside it has blocks with the same name (if the families were not modified in revit) and perhaps only with different properties, e.g. scale etc...? ?
a classic example are the trees or furnishings: revit appoints each block with a progressive number that makes the file very heavy and unworkable because they could redefine with a single command.
thanks to all
3dbix
...they are 2 sw of the same mother house, a small upgrade also on the management of texts in revit or at least an alignment between 2 after 22 years from the acquisition would be a discreet step forward from the point of view of the output.
Obviously they are not changes that generate profit (if you still need to export to autocad from revit the problem is yours, not autodesk).
Anyway, do you know there is a forum where anyone can ask for software improvements?revit ideasstarts to expose the problems, because until no one points out a possible defect, this obviously can never be settled
