kle31
Good evening everyone is kleids and I am a mechanical engineering student. I have to prepare an estimate of the costs for a process of double funnel and hairstyle. I better explain, we have to design a cup in aisi 304, 8 cm in diameter and 10 in height, starting from a sheet of 1mm thick. we have to make a hairstyle of a disk of diameter 200 cm, then a first funnel that reduces the diameter to 150 cm and height 2,6 cm, a second funnel diameter 8 cm and height 10. my group wanted to start from a sheet 50 cm x 50 cm and design a mold that cut 5 discs from 20 cm in diameter and then the molds for the next 2 funnels, even here they would like to make all 5 together, but I doubt if you can do it.
I would be very grateful if you could tell me the formulas to estimate the costs of the molds. if it is not possible to do as they say, even a mold that draws a disk at a time and 2 molds that put a disk at a time is fine. for hairstyle the required tonnage and 60 ton while for the funnels we are on 15/16 ton. obviously if you can make all 5 hairstyles together we will multiply the tonnage for 5. if it is not possible we will start from a coil and we will make one at a time the steps. Thank you very much for your help and patience.
