crash gestione layer
  • Thread starter Thread starter stiiiv
stiiiv
hi to everyone, except I didn't find a usual welcome section and then place my first message here. I say that in some forums you are "insulated" if you don't show up before. I am a student of architecture a second year, I downloaded from the autodesk site the version for students of autocad 2014. as already happened with autocad 2013 I have a problem that I can not solve. Just click on the layer management icon, exit the window with writing: autocad stopped working. This problem is really annoying because in practice it forces me to work on a single layer, or however if I open a file with other layers, I can only select them without changing their properties. I tried various things I found looking all night, someone talks about microsoft .net, someone says to use the classiclayer or layerdlgmode command but I didn't get any solutions. I also tried to repair the installation but nothing. It's a problem I've only got on the fix since the laptop works. I have the same operating system and the hardware is much better on the fixed, so it's not a hardware problem. it will certainly be software, but I do not know where to put hands because really trying the various solutions has not changed anything. then it seems strange that it is 2013 and 2014 do the same " joke" always on the fixed.
and if you type the layer command?
in such case if it appears you can not always keep the window anchoring it and making it appear at the mouse passage?
You could try with 4.5.
aaaaaah thank you very much, now it works, sincerely I do not understand why on the laptop with version 4 go, while here on the fixed while having version 4 did not go:) however with the 4.5 now it works perfectly, thank you very much :d
ps: so much that I am here I ask another thing. using the retini puts us a life to insert them into the disigned area, is there no way to "lighten" or however make filling faster via retini? Since I have to sample prospectuses for the university and I have lost hours and hours to put very few retinals because most of the time it kneades and does not fit me :\
