Jonny123
I have the following problem.. I have to create the divergent of a wind tunnel that basically is a pyramid trunk.... one of the two bases is a square (1600x1600)mm while the smaller face is a rectangle (1170x900)mm, placed at 3000mm one from the other.
This second face is what must be attached to the test chamber
the problem is this: after creating the two faces and joining the vertices with the lines, I can't make this figure become a volume...I tried with sweep but nothing...how do I?
I tried directly with creates a solid and setting pyramid trunk... but nn goes, then the problem is that I have 3 rays to set up. .
