creoson-beta-4-is-available
  • Thread starter Thread starter mamobono
mamobono
Does anyone use it?
but search files only in the job directory or even in the search path?
You find it here
h*ps://community.ptc.com/t5/creo-blog/creoson-beta-4-is-available/ba-p/476973
Does anyone use it?
You find it here
fundamentally what would be useful? looking for files in directories?
have you tried to install it and use it?
from the video I saw it seems to me that but I did not install it because I have intralink .
was just to share this info, maybe then someone will develop it as there is the source code
is a program that allows to automate various functions, e.g. deletion of files, operations on drawing, feature, family table, etc. by translating them (invisible) in jlink commands, one of the programming languages of creo.
I tried it and it works, but you need to know a minimum some programming language or scripting (javascript, php, python, java, etc.) where to insert these commands all well documented in the help.
I understood the basic logic, but I couldn't make it work. If someone wanted to help me...
cmq installs a local server (this is very simple: unique prerequisite for installing jlinks when installing creo) which receives as json inputs of the type (in the example I ask the distinct "plate_assy.asm")
"sessionid" "~sessionid~",
"command": "bom,"
"function" "get_paths",
"date": (')
"file": "plate_assy.asm"
in response you have:
"status": (')
"error": false
"date": (')
"file": "plate_assy.asm",
"generic": "base_assy"
"children": (')
"seq_path" "root,"
"children": [
"file": "bracket.prt",
"seq_path": "root.1"
"file": "bracket-2.prt",
"seq_path": "root.2"
"file": "plate_sub.asm",
"seq_path": "root.3",
"children": [
"seq_path": "root.3.1"
"file": "nut.prt",
"seq_path": "root.3.2"
"file": "no_solid.prt"
"seq_path" "root.4"
"file": "short"<screw>.prt,
"seq_path" "root.5"
in the site of creoson all these commands are very well documented.
What's the problem? that you have to launch requests with the right syntax and decode the answers that are full of parentheses, etc.
the beautiful thing is that you can use any programming language. Once with your language (I only know the vba) you can send the request to the server in json and read it, then you can use your preferred programming language. In the network there are classes for various languages to codify and decode requests and json answers.
However, a complete example is not found for the most used languages.</screw>
