Studio EDB
Good morning, I ask if someone is practical to zwcad in the management of custom menus (files .mns and .cuix) as I respond to the following problem:
I have old .mns menus (first I used them in autocad and worked) where there are instructions to insert a block (lampada) and fill in writings in the various attributes of the block (e.g. the luminous flux of 2500lm). the problem is that with zwcad text 2500lm becomes 2500lm, i.e. the tiny ones inserted in the .mns file (poi converted into .cuix) turns them into capital.
another problem: if you want to write 2500 lm (i.e. with the space between the number and the letters) it does not allow me to do so because it sees the space as a sending and stops the command.
Does anyone know if and how to solve these problems?
