ART ITALIA
Good morning:
a) using "multiple flap - loft flap " I built these two pieces inside the asm environment:
1) a tube.psm diameter 200 made of sheet metal, sp=2 mm
2) a tramoggia.psm (of d250 to 500x500, tallza=1000), also this tramoggia made of sheet metal, sp= 2mm.
*the tube must join a side of the hopper and must end in the side of the hopper. I managed to build the tube with a certain length off the hopper and certain length inside:
"Can you help me cut the tube, using the lateral sup of the hopper as a cutting element, or the line who shoots the hopper-tube intersection, so I can leave only the part of the outer tube to the hopper, eliminating the part of the tube inside, which does not serve?"
b) I am interested in understanding how to work on pipe constructions, hoppers, reductions, various intersections, to be built in sheets: Can you tell me if there are any tutorials, book, links, where to find information?
Thank you very much.
tyrant
tyrant
