data creation files for cartiglio
  • Thread starter Thread starter disperso
disperso
Good evening to all,
I better explain the title: in April 2014 I had to change machine for a disk problem, fortunately I had an updated copy of all the designs in itself until the day before.
arrived the new ws, copy and paste and away... "remained" as they are, I do not realize that all the copied drawings take as the date of creation that of the copy, therefore also those at es of 2006 take as date for the cartiglio that of April 2014.
in the chart, in the given section, I have always used "%{created|r1}" which is the only instruction that has always given me the right date.
obviously for subsequent drawings, no problem.
How can I solve this?
Thank you very much.
strange, did you copy it with explore resources or revision managers? because with explore resources should preserve the date of creation of the file.
is it not that it is the backup copy to have the creation date on the famous day?
if the backup has the right date, try to make a copy from command line with xcopy using as /k option (I think)
So... I didn't notice. I did the copy directly with explores resources from the disk I had backed up... and in fact if I make property on old drawings, I just get the famous date... which is the same as the copy.
the problem I partially solved it going to edit the cartiglio file and putting %{date of origin|r1} instead of "date creation"; so if I take a 3d of any old component and create a new design the date is the correct one... However, if I directly open an old draft, it is necessary to visualize the background and change the string of instruction.
At this point we must find out if there is a way to solve the situation. . .
Thank you in advance.
look, the only way we found here to solve the issue of the date of the carts is to put it by hand, especially if in the drawings put hand several designers and, as in our case, it was necessary to update several times the server accordingly all the links (to now 90% of the files reports as the date of rescue 2014...). Just create a custom property in the file (we chose it in 3d, then the dft inherited it, but you can also do it directly in the dft) and you put 3 seconds more, so in the cartiglio we have to put other data always by hand, it is not an extra field to fill that spasta.
only losers: everyone has his favorite format to write it, but unfortunately the whip is not well seen from human resources
in the various movements made by us the date of creation has never changed.
and say that's what we use on the cart.
I think it depends on how the files are moved from the various folders.
first I used %{created|r1} and I never had problems, even with the movements.
with the problem that occurred I did some tests and I passed to %{data of origin|r1} (if I don't put r1 doesn't work me), so it works and I inserted it on the default template with the cartiglio in various formats, but when I go to open an old design you see that it uses the template (which is then the same) old with the word "wrong" with which it was saved... then it touches me to view the right background and change the date string.. .
is there a way to solve this inconvenience?
I've made a plan to upgrade my cart.
I'm on vacation today. I'm on the spot tomorrow.
