flaminio
Hi, I've been trying to solve this problem in straus for a few days. I read the guide and nothing comes out, so much so that I begin to believe that you can't do or misrepresent:
data two adjacent brick elements are connected by the common face that binds them to each other in a total way (positions of each point of the first on the contact surface follow those of the second)
is it possible to disconnect the two faces, so that the surfaces can transmit, for example, only normal efforts to the face itself, but not cutting tensions?
Thank you for your help.
