delete text on multiple layouts simultaneously
  • Thread starter Thread starter snake_82
snake_82
Good morning to all I ask for help, I find myself in great difficulty.
I find myself having to reissue about 500 tables. each drawing is divided into about 20 layouts and I have to update the cartilage on all. My question is:
Is there a way to delete the same written in each layout in one shot?
until it was about modifying it with the "find" it all came very simple, but in this particular case I am forced to eliminate it.
Thank you in advance.
honestly I don't know if autocad allows you to do multifile search on the designs and then direct replacement with an empty string or full of spaces (at all effects a cancellation).
but if not mistaken it is possible to convert all drawings to dxf automatically (possibly using software as a9converter and similar) and then it becomes possible to use any texteditor that allows multifile search and replacement. research and replacement can at this point be done with regular expressions if necessary.
I come from mac and I am accustomed to using textwrangler to do such operations but perhaps a similar texteditor under windows should be knownpad+++ (but I do not know it quite well but from that little I have seen it seems perfectly able to do the operation).
I had already tried with "find" leaving the field empty, but unfortunately it does not.
