detoured.dll error - inventor not part
  • Thread starter Thread starter jlorenzo
jlorenzo
Hello, everyone.
I installed on my new laptop inventor 2015 but at the start from the message "impossible to start because the detoured file is not present etc...". the file is present. I did some research and it seems that all the products autosk 2015 They suffer from the problem. practically is a library that is not recorded due to the presence of two video cards (an integrated intel and an amd with dedicated memory).
autodesk says to solve using these two methods
use the amd catalyst control center and change the global setting to something other than maximum performance. in some cases, it has been reported that the force power saving graphics choice is the only one which resolves the trouble.
update the driver of both graphics cards. obtain the drivers from the websites of their respective vendor sites (amd & intel). install the amd driver first before the intel driver.
I tried both without result, but I noticed that in the amd catalyst control center (program to manage the settings of the graphics card) if I act on the option of the number of screens supported the detoured problem is solved temporarily.
I'll explain better.
I had two enabled monitors, imposed on 1 and inventor part and can work without problems until the shutdown of the pc; at the restart of the machine, starting inventor reappearing the detoured error, I return on the amd catalyst and imposed monitors from 1 to 2... inventor works again. practically every ignition I have to do the exchange of monitors from 1 to 2 and vice versa.. .
Does anyone have my problem?
