display of deformed in fem analysis
  • Thread starter Thread starter rosario nic
rosario nic
- - - updated - - - -Bye to all,
I've been banging my head for a few days with a solid edge st6 simulation and I can't find the solution. the simulation consists of 5 pieces connected to each other with a connector glue. assemble the model, the load, the constraint, I create the mesh and the mando running. nastran nx provides the result but I can't see the deformed with all colors. Looks like it's unloaded. then I do a test simulation with a swing beam with a cut load at the end and it works. I also tried to simulate the beam with the same conditions of constraint and load but consisting of two different section beams to see if I correctly define the connector glue and it works. How come, in your opinion, with the first model I can't see the deformed?
Sorry I'm late.
the problem concerned the display of the deformed structure.
I did the following test. Prova.webp and how you can see the beam deform and color. therefore the definition of the model (loads, constraints, connectors) was correct. my structure did not deform and had the same color, relative to the voltage of lower von mises. then I deactivated symmetry plans that I used to build the axieme (via the mirror command) and magically managed to get deformed with all colors.
I hope I was exhaustive.
