distance between two elements in an assembly
  • Thread starter Thread starter driver
driver
Hello, everyone.
I can't give a distance between two pieces in an assembly. I try with the remote control between elements in the pmi menu, but it gives me a blocked distance.
How can I do that?
I suggest you do the exercises first.
Anyway to do what you want to do you don't have to use pmi...you have to use relationships!
I use relationships to align, make parallels etc but I do not find the distance to set!
follow the advice of Leso or let us know what your problem is.
with the pmes you cannot move the pieces, the pmi are only of help to verify the distances, that is to quote on 3d.
Maybe put an image.
Sorry I'm late to answer.
for that thing I solved, only that now I have a problem in binding two objects in an assembly, I completely unchange the whole structure.
I would like to post all the subfiles, only that the zipped folder is more than 1 mb....
