distinte base
Fabry085
goodwill to all, I have a question to ask you inherent in the title, the company I manage deals with design and construction, our products are several complex and complex are the distinct base, often arrive at 4/5 levels, our designers are constantly developing and in everyday life we find ourselves having to revise or replace a component and therefore change the distinct base, the problem is that at times the component in question is common to several inventors maybe even with external software?
I hope I've been clear, unfortunately I know I'm very bad in explaining. Thank you in advance.
you can do if you use the vault. only csa is that then you have to open the assemblies and recheck the constraints because if the parts are different it can be that the constraints jump.
exact, you just need to be aware of the big organizational commitment that requires the use of the vault.
the beginning will be a nice adventure, difficult to deal with without a valid advice, then it will be an inseparable working partner.
Yes, but it's not that hard, indeed... I also use the vault to sync templates and styles, so everyone works locally by downloading them and the upgrade is controlled by vault that does not allow everyone to customize without wanting it all you want.
